Help with fuel mileage!! 255 cams and dyno tune hurting economy...
Hey, guys. I have a 2010 RKC with the factory 96, 255 cams, Super Tuner with dealer dyno tune, stage 1 air filter, and Rush slip on mufflers.
Before the cams and new tune, I could routinely get 250 miles out of a tank, and now I am lucky to get 200. In fact, I am usually looking for a gas station at about 150 miles, which is yielding 35mpg or less, roughly. And I don't ride exceedingly fast or make a habit of hard accelerations.
So...what can I do to help the fuel efficiency of my bike? I like to plan long rides every so often, between 1,000 and 2,500 miles, and I would like to get my bike to peak efficiency. I invested a lot of time and research in tuning my diesel pickup for peak fuel economy with great results, but I have no idea where to start with a V-twin.
Is it possible that I have a less than ideal dyno tune? The bike runs great...plenty of power for what it is.
Would upgrading to 103 jugs help me out, and going with the Screamin' Eagle base map on the Super Tuner software?
What about a Power Commander? Do they offer a more efficient tune for the 96 with 255 cams?
Any helpful input would be appreciated. I keep hearing of this mythical 45+ mpg that people talk about, but I am nowhere near that.
with cams it'll be hard to restore near stock mpg.
a catless header will help to pick some up though
the prime culprit is probably the tune and it may be improved, regarding the pcv I smell lots of rich running bikes with pcv's. the "tuner" just makes everything rich, 'cause "rich" means more power, right ? ( no)
my MPG is right at 43 mpg measured over thousands of miles at 70 mph.
2009 FLHTC ( so more weight and wind resistance than you).
96" ness big sucker, stock headers ( no cat in 09) and supertrapp tuned mufflers.
My ECM is stock, I have nightrider.com XIEDS on my o2 sensors
I deliberately sacrifice the power gains of cams for the mpg I need/want when touring
building your motor further ( 103" etc.) will increase comsumption
Mike
Mike
Antonio Balls (07-08-2016)
Very insightful...thanks. I guess I should point out the obvious: I'm open to changing my setup however necessary to tune for peak fuel economy, including downgrading power or swapping cams again to something more suitable for highway cruising. Does anyone have any experience with this type of tuning specifically?
I know the 255 is a strong bottom end cam and probably not ideal for long hauls. All of the reports on here, however, suggested that fuel mileage did not change after a 255 swap. That's why I'm wondering if I have a bad dyno tune.
When I first got my FLTRUSE I was getting no better than 36 MPG. After my Stage lll up grade and dealer dyno I was averaging only 30 MPG!
My tuner was the SE which later I found to be CRAP!
After doing my research, led me to Doc Weaver in Mineola FL. He had to install the TT Master Tuner. He spent 2.5 hrs on the fuel map alone. After several hours he got me another 10 HP & 10 TQ. I no longer have throttle hesitation and my fuel average is 40 MPG!
You need to find a reputable tuner with great references in your area. Have it retuned and dynoed!
Here are my mods:
Stage lll Engine *Modifications:
Sach's Polished & Ported Heads, TTS MasterTune, T-Man 625 Cams, Adjustable Push Rods, Full Sac 2" Baffles and X-pipe, SE 10.5: 1 Forged Pistons, Titanium Valves, *Dyno tuned @ 110HP 120 TQ.
Here are my mods:
Do you have your cables for the SE Pro? If so, you could open the map and see if they are running a rich open loop AFR table. If you have trouble with that process, go to the ECM section of the forum and post in the SE Pro tuner sticky post. Many people can help you out.
BTW, no 255 cams but 96" duals, pipes, AC and SE Pro and I've done my own tuning and still get 42-44 mpg.
mikebaby
Hey, guys. I have a 2010 RKC with the factory 96, 255 cams, Super Tuner with dealer dyno tune, stage 1 air filter, and Rush slip on mufflers. Before the cams and new tune, I could routinely get 250 miles out of a tank, and now I am lucky to get 200. In fact, I am usually looking for a gas station at about 150 miles, which is yielding 35mpg or less, roughly. And I don't ride exceedingly fast or make a habit of hard accelerations.
You probably are still running closed-loop with your setup, and if so I would assume the tuner set the Lambda table to .98 in the cruise range, which is the richest value possible for closed-loop. That wouldn't be much richer than stock and should realize better than a 20% drop in gas mileage. OTOH if he set yours to open-loop (O2 sensors disabled) by setting Lambda <.98 there is an almost infinite range of AFR options, and if that's the case you could be running considerably rather than marginally richer than stock.
I would take the bike back and ask them how they tuned your bike, then get back to us, and a screen shot of the Lambda table would be revealing. You might ask them your options for setting the cruise range for better mileage. I would not want to mess with a good tune at WOT, as you need maximum power when it is required, and since you aren't in that range often (are you?) it wouldn't affect mileage significantly.
That said, I am not saying the tuner provided you with a poor tune, but it may simply require a reassessment of your needs. I would discuss it with them.
techbill (09-20-2017)
