MT90-MU85 tires
The tires sizes you listed really have nothing to do with the axel size. The MT has a slightly higher profile, higher load rating and is approximately is a 140 width. The MU is a 130, lower profile and load rating.
I run the MT90-16 on the rear, and the MU85-16 on the front of my Road King, both wheels are 3/4 axel (agian no factor in regards to the tires sizes you listed).
I am running Dunlop E3's.
Your front axel should already be 1"
Your rear is currently 3/4" and it is fairly easy to change the 06 rim to 3/4" bearings. You will have to use your rear pulley since 2000 used the wider belt. I did this on my 2000 RKC with no clerance issues and have over 10k on this setup.
The MU is slightly wider with more carrying capacity, but may not fit the bike.
some do, some don't
I know a few guys running mu85 on evo baggers, mine wouldn't- clearances were too tight, and I'm not gonna eat up a belt for a marginal increase in capacity.
If really wanted you could gain some room with a narrow belt ( and pulleys) but that's pretty costly for labor, unless you are already pulling the swingarm off.
smarter is a chain conversion to gain width.
chain is stronger, easier to replace, gearing changes with a easy sprocket swap etc etc
2 reasons for the belt drive
low maintenance
reduced noise emissions
mike
The two wheels you mention have the same rim size of 3" wide. The axle sizes don't matter! The MT tyre is nominally 130/90 and the MU tyre is 140/85, in other words about 3/8" wider. The MU was fitted to later bikes such as the 2006 bike, for its higher load rating. It will fit your wheel and you should find you can fit it to your bike. As it is wider than the tyres you have been using there is a possibility you will need to trim your belt guard, to stop the tyre rubbing against it. I ran 140 tyres on my 1990 Glide by doing that with no other problems.
Hope that helps!
