Disabling ABS
#82
I've only seen similar posts once or twice before. How many times have you flushed and changed the brake fluid since 2010? Was it corrosion in the hydraulic control unit? Did they actually rebuild the HCU or replace the entire ABS unit?
Thanks
Bill
#83
I just bought bike. Dealer service records show all maintenance performed by dealer before I got it. This happened couple days after I took it home. Dealer changed HCU with new from the factory. Tech did say looked like a valve was stuck not allowing fluid to go to rear caliper from HCU. He also flushed the front fluid just as a precaution. Bled brakes with the tech tool and said all was good now. Harley wants the old HCU back for evaluation. On the bright side the guy I bought bike from says he will pay half the bill of $800.00.
#84
Did the dealer service records show brake fluid flush and change?
If you hear back from the MoCo about the HCU I'd be interested to know what caused the problem.
Enjoy the new bike
Bill
#86
#87
#88
Just experienced the rock hard rear pedal/no rear brake issue on a 2010 FLHRC. Fortunately, front brake was working. Still was a "raise the hair on your arms" experience. Been on Non-ABS bikes for 45 years. NEVER had this happen. Have almost always done my own wrenching on ironheads and shovels. When I retired, I thought---I'll treat myself to a new/er HD. What a "futzing" mistake on my part! Have successfully learned enough here and on other forums to finally make it comfortable w/o having to take it to HD. Guess that's about to change. Has less than 8,000 miles miles on it. Runs great now. Just won't stop! GEEZ. Anyone have an old shovel they want to trade. LOL! At least a guy can work on those...
#89
