Disabling ABS
Disabling ABS
I am not a fan of ABS being a long time road racer it takes away my control. It has also gotten me into trouble on a couple of occasions. Riding down a steep winding pass in VT. last year I hit a bump in a turn and the ABS released my front brake sending me into the oncoming traffic lane! I can see the advantages in wet or sandy conditions but as an agressive rider it scares me more than helps me.
My question is, if I pull the fuse for the abs will it disable it? And if so, is there any reason that I can't put a switch in line to disable it on command?
Hope someone can help! Thanks, Scott
Don't disable the ABS, the world will come to an end, your family can be sued, you can be sued. Only those bike that have ABS can be safely ridden all other bikes will never stop and will cause terrible repercussions. Yes it can be disabled if you desire.
triumphsf79 (03-25-2017)
After this thread has been around for a few days you'll have a zillion replies that instead of addressing your question of how to disable the ABS, will be telling you how lucky you are to have ABS.
They will tell you that an ABS system works exactly like a non-ABS system up to the point of impending wheel lock up, and if your ABS activated then you would have locked up your wheels and probably crashed if you didn't have it.
Now please excuse me, I need some kool-aid.
It seems to me that if an ABS could be found responsible for causing a bike to go into the oncoming lane, there could be a major liability situation. The only thing I don’t like about the ABS on my Ultra Classic is the hard to get use to sound it makes when you have to get on the brakes hard. Twice the ABS have prevented me from loosing control while attempting to avoid a collision.
quick question. several times I have been puttin' down some side roads and just used the rear brake alone and the pedal went down and got this mechanical clicking sound with the bike stopping in a aggravating grabbing sensation. I'm usually a front and rear brake guy but some time trail brake for a purpose.
This is the first bike with ABS and is this that crazy sensation I'm getting???
