exhaust popping
Old 03-21-2012, 07:38 PM
BenRK05's Avatar
BenRK05
BenRK05 is offline
Hey bro I just went thought the same thing on my 05. If you look in your manual you will see that the exhaust clamps are a one time use only. Go to the stealer and get some new ones. They will cost $17-18 for the set. Then torqe them down to 40-60 lbs.
Old 03-21-2012, 08:32 PM
TO34's Avatar
TO34
TO34 is offline
Originally Posted by BBStacker
Before you spend more $$$$$$$$$$$$....make sure your pipes are all the way on and forward, move the clamps as close to the edge as possible and use the correct torque. Eliminate all possible sources of air leaks 1st.
This was my issue! I went & looked up the correct torque specs for all the exhaust clamps & then ordered a new set of the rush torca clamps because I doubt the "typical" claps were doing the job. A lot of after market slip on's tend to use a thicker steel then the stock HD's
Old 03-21-2012, 10:12 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
Holy crapola!!! Ridgecrest I feel for ya bro! Only went to China lake on deployments thank gawd.
Old 03-21-2012, 10:36 PM
roadgliderick's Avatar
roadgliderick
roadgliderick is offline
the down load still makes the bike lean they have to be compliant with the epa i dought its a leak from the clamp. it could be but not likely when u ad the air cleaner and tru duals or a 2 into 1 its gonna run lean. my buddy just added the exieds and it did help but it still has a little decel pop. until u get a tuner thats how its gonna run. i have had the power commander 2 of em in fact and thy both went bad and i also had a sest the best tuner i have bought today is the thundermax everyone has there preferance mine was the thundermax i havent had any issues with anything sinse.
Old 03-21-2012, 10:48 PM
Skippy97's Avatar
Skippy97
Skippy97 is offline
Hey there,
Had the same issue. Put V&H slip ons on my '11 FLHX with SE Heavy Breather. Did a standard Harley download. Lots of popping on deceleration. Two months later dealership found my spark plugs were white when I brought it in for check-up...the bike was "hesitating" at low speeds. Engine was running lean.
Bought a SERT and had dealership do a Dyno and tune.
No problems since.
Old 03-21-2012, 11:27 PM
TO34's Avatar
TO34
TO34 is offline
Trust me, its not been fun, thankfully only 10 more months left till I can rotate out.
Al951
06-28-2012 07:17 PM
cbchev68
09-12-2011 06:18 PM
chromedome
05-24-2008 10:12 PM
garand
Exhaust System Topics
04-18-2008 07:10 AM
ltkris
07-05-2006 01:20 AM
Quick Reply: exhaust popping
