Garage Door Opener Mod. Done - with pics.
#91
Cheap and Lazy
Being cheap and lazy, I got some velcro and velcro'd my remote under the auxiliary switch housing on the inside of the left side looking forward, kinda tight but fit. It's out of sight, easy to activate, out of weather, and when the battery goes, easy to remove. Just a thought.
#92
#94
Do you have the push button odometer reset type switch? if so, the only thing you could do is add a second set of wires (splice them in) to the second remote - but you will be opening both doors every time you pushed the switch.
Or you could find 3 position momentary toggle or rocker switch. Run one set of wires from the top of the switch to the first opener, and another set of wires from the bottom of the switch to the second opener. Middle position is off, push up for door #1, push down for door #2. The switch should be one that automatically returns to center so it opens the circuit (stops sending signal) when you let go.
Here's an example: Amazon.com: Amico AC 250V 3A on/off/on Momentary DPDT Toggle Switch with Waterproof Boot: Home Improvement
#96
Just did this mod, for anyone interested you can purchase an on/off (not momentary) switch w/ rubber boot here
http://www.allelectronics.com/make-a...USH-OFF/1.html
http://www.allelectronics.com/make-a...R-PB-21/1.html
About $2 plus shipping
#97
#98
Garage Door Opener Mod (Liftmaster, working intermittent?)
Last weekend, I added a garage door opener switch to my '09 Street Glide. I used a Liftmaster opener (Amazon, $25) and the Harley momentary switch (PN 71764-07, $35) originally designed for the CVO Electric Saddlebag lock.
For starters, the Liftmaster opener works great, in fact I have two of them and they both work great. When I soldered the switch wires to the opener circuit board, the opener now works intermittently even before I installed the switch on my Street Glide.
So, I unsoldered the wires, and the opener works fine again. Tried this also on the second Liftmaster opener and same thing. I checked the connections, replaced the battery, (and drank a beer or two while I was wondering what the heck was going on) but it didn't make any difference.
I tested the opener switch with a voltmeter before I soldered the switch wires to the circuit board so I'm relatively certain I made the right connection. I am also looking at the pictures in this post, and it looks the same too. But, either I didn't solder the wires to the right circuit on the opener, or something else is wrong.
Any ideas?
Any ideas?
#99
Installed a "good to Go" opener. got it real cheap. Powered by hi beam. Hit headlight switch from lo -hi-lo-hi and garage door opens, only had to remove headlight for access. total job time, about 15 minutes. No extra holes. Absolutely invisible.Worked flawlessly for around 5 years now, so maybe it'll be OK.Trickiest part was mounting the receiver to the wall, replacing the stock unit, but even that was pretty easy.Oh, yeah-2008 FLHT.
#100
