85 to 90 Series on RKC Rear Tire?
Local HD dealer has been waiting since shortly after Christmas for a Metzler WWW size MU85B-16 which I understand to be the same as a 140/85/16. Apparently, Metzler 140/90/16's WWW's are all over the place. My question is, can I use the larger 90 series tire on the rear of a 2008 Road King? If so, what should I expect relative to fit, changes in motorcycle height or handling? Would or would you not change the tire size?
Thanks for the help.
Just got off the phone with the dealer. They said a 150-80 from Metzler should fit a 2008 RKC. The load rating is just a little lighter than the MU. Should not be a problem for a guy with a solo seat and no tour pack. So here we go with 150/80 Metzler WWW in a couple of days.
Thanks agin for the help.
I just checked - you should have a narrow belt. Older bikes have a 1 1/2" wide so yours will be visibly much narrower.
I don't know if they do a WWW version, but the 150/80 Avon Venom is the same load rating as your stock tyre, for future reference.
