Fitting stock heat shields on Jackpot 2-1-2
Just wondering if there is a trick to this?
Had the dealer install the new head pipe because cams were being done at the same time. Now the front heat shield has about a 1" gap where it's supposed to meet the rear pipe shield.
Before I start trying to adjust these, is this normal or should I try playing around with them.
As a side note, you almost can't notice it because of the ceramic coating. Nice pipes!
TedMan
Yeah, I'm experiencing a similar issue and I'm doing it myself. The gap between the rear heat shield and the two front ones is much bigger than it should be (approx 1/8 to 1/2 inch). It seems that the worm screw clamp brackets on inside of the heat shield prevent it from fully setting down with the other two. Moving the shields haven't helped, because it's not an issue with the two front ones. They mount up just fine.
