cruise control... not working ?
Old 04-02-2012, 02:24 PM
Hot Rod King's Avatar
Hot Rod King
Hot Rod King is offline
Default cruise control... not working ?
Ok, Im not normally this challenged but something doesnt seem right. This is the first bike I've ever had that has cruise control. I went to test it out yesterday and it didnt seem to be working. I first turned it "on" and then when I got to 70mph I pushed the button over to "set" and let my hand off the throttle. It immediately started slowing down from 70mph. Wtf am I doing wrong ? Thanks
Old 04-02-2012, 02:32 PM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,300 Likes on 780 Posts
That's about all there is to it. Check your brake lights and make sure all are working. There is a switch under the front brake lever that if broken will cause the brake lights to stay on all the time and wont allow the cruise to engage, maybe check fuses also.
Old 04-02-2012, 02:49 PM
2heritagespringers's Avatar
2heritagespringers
2heritagespringers is offline
Check the roll off connector. The idle cable is many times the culprit. Do yo have a Service Manual to follow procedures to check cruise?
Old 04-02-2012, 02:54 PM
modes's Avatar
modes
modes is offline
WHen you hit the set button...did you just blip it or hold it. A blip of the button should be all it takes. When you turned the cruise on did the red cruise icon illuminate on your speedo? If not check your fuses and brake switches as mentioned. When set it would change to green.
Adam
Old 04-02-2012, 03:12 PM
Oil City Outlaw's Avatar
Oil City Outlaw
Oil City Outlaw is offline
I had the same problem. The front brake lever was not engaging the brake light switch enough to break the contact to turn off the brake lights. Check to make sure your brake light is not on at all times like mine. I did not use my Cruise that often so I did not know how long I had been riding with my brake light lite!!!!
Old 04-02-2012, 04:46 PM
METALKAT's Avatar
METALKAT
METALKAT is offline
Happened to me but is was the rear brake switch leaking, I have a 2009 Fltr and that switch ended up being a recall. Not sure about a 2006 but any brake issue that throws a code on mine disables the cruise.
Old 04-02-2012, 08:13 PM
Hot Rod King
thanks guys, Ill check it out. It did turn red on the speedo when turned on and did go to green when I hit the set button. but as soon as i left off the throttle, it went to red and bike slowed down immediately.
Old 04-02-2012, 08:16 PM
mac1911's Avatar
mac1911
mac1911 is offline
Really sounds like the roll off switch or a brake switch.
johnod
EVO
07-27-2017 01:47 PM
ZBear
18
06-30-2017 03:30 PM
bigpappa160
05-27-2016 12:09 PM
Road Hawg
06-12-2011 06:11 PM
ebaswell
04-28-2005 03:56 PM
Quick Reply: cruise control... not working ?
