Anyone running a Procharger supercharger? How hard was the install? Any disappointments? I'm thinking of getting one. It says it's pretty much a bolt on with no motor work.
the reads say bolt on in less than 8 hrs. easy way to get a ton of power. I noticed on this forum, they are not very popular.......most of the folks here do upgrades one by one and inch worm there way from the bottom to the top. the pro charger is a cut to the chase, upgrade and be done with it solution. If you get one, would recommend the extra two year warranty on the impeller.
Call Frank at dragos bike works
He's a sponsor here and the resident supercharger expert
His website has a bunch of pics of supercharged hds and he offers cams and headwork specifically designed to work with them. Some very impressive dyno sheets too.
Frank will give you all the info...I was going the Procharger route and installed a 120R instead. Cost was about the same. With that said, I probably will install a Procharger this winter.
