Wanting to hear some tunes on the Road King
I have played with several systems over the years. The absolute best bang for the buck is a pair of neckband lightweight headphones, can be searched for on Ebay or Amazon.com under that description. They are designed with headband that runs behind your neck allowing you to wear these with 90% of helmet styles. Sound quality is outstanding and they are easy to use, and much more comfortable then "buds." When you stop just remove your helmet and drop the headphones down around your neck, when ready to ride, raise 'em up and put on your helmet. They make a closed and open style ear piece, depending on model, that can block out most outside noise and wind, or open style to allow outside noise and cooling in. Both work well depending on your preference. You can buy a good pair of these for $10, or 2 pair and keep a spare with. If you want an "audiofile" type sound thru these headphones, you can buy a small headphone amp that clips on or bundled with your player. They have 8- 80hrs of boost and are rechargeble, these cost about $25 for a good one, check out FIIO E6 amps. They also make IPOD specific cables and wireless bluetooth set ups. All good sounding and for a fraction of speakers, amps etc.
I installed a standard radio and 2 500 watt amps for front and rear which will fill the air with music but still allow me to hear the maniac honking as he tries to run me down, it has happened, I also ride with a camera system to record dumb-asses, for the record.
rk sounds
I just installed a boss amp and handle bar speakers on my 07 rk the amp is under the seat and I run an apple 5th gen shuffle . the speakers were spossed to be 3 inch but I got 4 inch ones the sit close to the center of the fork lock top behind the windshield after I installed this I went 85 mph down the freeway and I could hear the music just fine and I did not have it turned up all the way , im also happy my boss unit came with its own volume control as the apple control is so small its hard to turn it up with gloves on I did a lot of research before I ordered the boss . the reviews were mixed but for less than 60 for the amp speakers and pretty mush pre wired compared to kuryakan at 300 for just the speakers im happy
I think I've settled on the HD Boom Audio windshield mounted system. Many who have had both report it works better than the bar mount system, and I figure I probably won't hear any stereo if the windsheild is removed anyway. May not be the end all, but looks like good quality, and I like the factory looking controls. Plenty of youtube clips of these out there.
