How do I know if I have an exhaust leak on my FLHTK - Harley Davidson Forums
Sponsored by: Fuel Moto USA
P
Thread Tools Search this Thread
Old 04-10-2012, 07:23 PM
Fathertime500's Avatar
Fathertime500 Fathertime500 is offline
Senior Rider
Default How do I know if I have an exhaust leak on my FLHTK
Just installed Vance and Hines power duals with monster ovals.I also put on a screaming eagle vintilator and power vision. I think I have a front exhaust leak but could just be the air intake. How can I tell?
Old 04-10-2012, 07:48 PM
zoozoo's Avatar
zoozoo zoozoo is offline
Does your exhaust pop when decelerating?
Old 04-10-2012, 08:03 PM
sedouglas sedouglas is offline
One Of The Regulars
My heavy breather makes it sound like an exhaust leak but more from in front than while on the bike. I'd be willing to bet that you would be able to hear an exhaust leak while in the saddle a lot better.
Old 04-10-2012, 08:11 PM
rdunn22's Avatar
rdunn22 rdunn22 is offline
New Member
Try covering the ends of the mufflers with your hands while the engine is running (use gloves to prevent burning). This will sometimes let you hear any leak that may be elsewhere in the system.
Also look for any black or carbon around any of the head pipes or any other joint in the system.
Old 04-10-2012, 08:14 PM
DBAGR's Avatar
DBAGR DBAGR is offline
One Of The Regulars
Quote:
You can check with something as simple as an incense stick or anything that puts off enough smoke to easily see. With bike idling hold it below area you suspect is leaking and watch for smoke to move around. zoozoo is right about the exhaust popping on decel, if it doesn't pop your probably OK.
Old 07-14-2014, 12:39 PM
dogwalker58 dogwalker58 is offline
New Member
Hi, I'm new to the forum. I have an 06. Fxstsi with SE ll slip ons. Vance and hines fuel manage box and SE breather. My bike pops on decel some . Was worse before I changed out all gaskets and clamps but you have to do it all at once, no shortcuts, no repositioning parts etc to be sure that all is new and tight. And even then it'll pop a little. With stock muffle you just don't hear it as loud. My advice is to try not to decel that often if possible.
Old 07-14-2014, 12:48 PM
gliderman gliderman is offline
Exhaust "popping" can also be, and usually is, a result of tuning. Don't automatically assume you have a leak because of the popping. With bike idling, preferably in confined area, carefully blow some smoke from a cigar towards suspected area of leak and watch to see if smoke is blown away by leak. Otherwise, dialing in your tune may be necessary. I have no exhaust leak on my 13' RG and have run multiple auto-tunes with a PV to dial it in. Bike runs strong but still pops on occasion. I wouldn't sweat it...
Old 07-14-2014, 01:15 PM
roadking2014's Avatar
roadking2014 roadking2014 is offline
cigaret or cigar smoke has always worked for me. Incense stick as mentioned above will work. I guess there's more technical methods but I've never been one to look up a chickens butt to see if they were ready to lay eggs.
P
Thread Thread Starter Forum Replies Last Post
Power Duals leak at crosspipe. fl1996nos Exhaust System Topics 3 05-13-2015 06:15 PM
Harley exhaust gaskets VS screaming eagle gaskets robotDan Exhaust System Topics 10 03-07-2015 01:13 AM
Power duals install hammerr New "Rushmore" Models 10 01-05-2015 03:29 PM
Vance and Hines leak Nick412 Exhaust System Topics 7 12-18-2014 02:02 PM
Vance and Hines Big Radius Sound shawnkmills Exhaust System Topics 3 07-08-2014 07:59 AM
Tags
cycle, davidson, exhaust, find, front, glide, harley, header, hines, leak, motor, motorcycle, pipe, sounds, street, vance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
