trans shift shaft arm loose??
I have a 11 flhrc and it appears the arm that attaches to the shift shaft that comes out of the trans is loose...is this normal?? I got a mirror and tried to look in behind the inner primary case but it is hard to see...it appears like the shaft itself is not wobbling just the arm...I tried loosing and tightening the allen bolt but it didn't seem to make a difference...its not real-fall off loose...just has a little play in it...
I have a 11 flhrc and it appears the arm that attaches to the shift shaft that comes out of the trans is loose...is this normal?? I got a mirror and tried to look in behind the inner primary case but it is hard to see...it appears like the shaft itself is not wobbling just the tarm...I tried loosing and tightening the allen bolt but it didn't seem to make a difference...its not real-fall off loose...just has a little play in it...
It happens but haven't heard this on a newer bike. I'm sure your warranty will cover it. Here is some reading from a guy that sells a lever to fix it your self...
http://betterlever.com/index.php
I have personally replaced the loose stock shifter with a better lever on a 2008 flhx. Took all of 15 min. There is a recess in the back of the primary casting that allows you to r&r the lever without having to pull the whole primary (ulike older models) If this happens again after your warranty replacement,I would highly recommend this route.
Its simple,take pinch bolt out of existing lever,pull lever outboard while tilting top of lever in towards bike.The recess in back of primary allows enough clearance for lever to clear the shaft. Install is reverse. I have heard some dealers are still charging the 5-6 hrs or so to pull primary/swap levers,as with the older models.If you have the recess in the back of your primary,this is a simple do it your self swap.I also installed a better lever on my 96 fatboy (no recess),and had to cut the old lever off. It took me 3 hrs to do. still way cheaper than dealer.The better lever is stainless steel and of much higher quality than stock.
My 2011 ultra rear shift lever at trans had more slop than I wanted to see. 15k miles. This yr bike the lever can be removed without removing primaries and covers. I took them all apart , removed the shift lever, behind the lever there is a small snap ring and a washer. I put an additional .010" shim washer along with the stock washer to remove some of the in and out end play. Installed a new shift lever from harley and tightened the new bolt extra tight with red loctite. Put it all back together and all is good.
