To much oil pressure
Just put a set of andrews cams in my 2001 Electra Glide. Everything was fine until I got on the interstate and had higher rpm's. Went 5 miles and it started blowing oil out the air cleaner. I got it home at low rpm's and it blew a little oil but nothing like the high rpm's. Can't figure what could be wrong just from changing the cams. Any ideas. Thanks
Hmmmm.
About two weeks ago I had the S/E Hydraulic Cam Chain Tensioner Kit installed by a very good mechanic.
All seemed well until I ran the bike at freewayspeeds for about 20 miles.
When I got to my destination I had oil dripping from the bike and all over the right side of my bike.
I drove it back to the shop where the work was done.
A couple of days later he called me to say the bike was ready.
Problem was one of the o ring seals in one of the push rod cover tubes had not seated properly.
All is fine now.
If you're oil is coming from your air cleaner the first think that I would check would be the oil level.
Could you have perhaps over filled the engine?
All is fine now.
If you used adjustables then you didn't disturb the top rocker boxes so you can rule out up top (the possibility of putting in a gasket the wrong way). A misaligned cam would cause it to run shitty but wouldn't puke oil so you can rule that out. That leaves the oil pump or the oil feed holes. If you didn't disturb the pump you still should align just because, but that probably isn't it. That leaves an oil feed hole blocked. If you pull the cam plate you should have changed those two little o-rings on the left side. I would open the chest and pull the plate and pump and replace the rear pump o-ring, the two oil feed hole o-rings, check the gerotors and see that they stand proud as they should, replace the front o-ring between the plate and pump (assuming you kept the stock pump and plate) and then put it all back together and align the oil pump by alternately tightening the proper screws whilst turning the rear tire.
Ok I tore the bike clear down again. New o-rings and gaskets. Checked oil pump and relief vavle. Put the pump on first and left it center up, then the cam plate. When it was all back together I warmed it up and changed the oil. With it warmed up I have 30psi at idle and 44psi at 3500/4000 rpms. Going to check the gauge next, to be sure it's reading right. Out of ideas. Help!!
