04-17-2012, 03:22 PM
Mine works perfectly too. Rod has been very fair and helpful when needed. If tire pressure is right you may need the model for lowered suspension.
04-17-2012, 08:25 PM
Thanks all for the suggestions and info. I have contacted Rod, President of Wheeldock, and he has been quick to respond to all my emails and send suggestions for things to check, so no complaints there. I will double check my shock and tire pressures again just to be sure I'm not crazy. Also, I think I will have my buddy take his wheel dock off and switch with mine to check if it makes a difference on either bike. Hopefully that will settle the issue and Rod and I can work out a satisfactory fix.
__________________
2011 H-D Ultra Limited
2008 Honda GL1800 Goldwing (Traded-in)
2003 Honda VTX1300 Retro (Traded-in)
04-17-2012, 08:49 PM
My 2011 FLHTK is super easy to put up on the stand...... Seeing how your friend has one I would try the old switch-a-roo and see how it works.
When I first got mine, a couple of times when I got home, I had problems getting the bike on the centerstand then I realized to pull in the clutch so the bike would roll....DUH
Besides my own stupidity the centerstand works great!!
__________________
Lovin' my Limited!!!
2011 Rootbeer Ultra Classic Limited - 2011------
1990 Yamaha-ha Venture Royale (What a project but Back In The Saddle!) - 2009-2011
1985 Honda V-65 Sabre (tried to kill me) - 1995-1996
1977 Kawasaki KZ 650 (and I was hooked!) - 1991-1995
04-17-2012, 09:39 PM
No issues with the EZ center stand that I installed last week on my FLHX (CS-09L) as a matter of fact, it goes up so easy that I often double check it because I can't believe it is fully engaged.
I would call Rod at Wheeldock tomorrow. He is a very nice guy and I am sure if there is an issue he will know what the issue is right away. My guess is that it has something to do with the height of your bike vs the stand you installed. I was going to order the regular CS-09 and Rod explained that I needed the shorter CS-09L version due to my SG is a shorter bike. But pure speculation on my part. Call Rod, he will know for sure.
Good luck.
__________________
2012 FLHX, 4"Rinehart Slip-Ons, SE Stage 1 and download and a few pieces of chrome here and there.
04-05-2013, 06:41 AM
I installed mine on my 2012 FLHTK and it worked great for a few months....until my 63 year old legs broke the foot lever....I'm pretty sure it was my technique but I did notice that when I held the bike vertical and went to place it on the stand....that the bike seemed to rock a little bit....I have sent it back and Rod was very helpful....so now waiting for it to return.....the legs on mine may have been longer ....I will call Rod and ask him about that....thanks
Tags
center, code, cs09l, davidson, discount, dock, ez, harley, installation, part, pictures, reviews, stand, wheel, wheeldock  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
