2005 Road King front shifter shaft
Old 04-17-2012, 10:32 AM
skdvr's Avatar
skdvr
skdvr is offline
Default 2005 Road King front shifter shaft
On my way in to work this morning, I was getting off the Hwy and downshifting and my shift lever broke free. I thought that the shift bar had broken free. I pulled over and noticed that it was still attached. After some messing around I figured out how to get it in gear. I attached a video that shows the problem since I thought I would never be able to explain it properly. I am interested to hear your thoughts about if you think the shift shaft just needs to be replace or if it is bushings. If it is bushings is it something I can replace with general home tools without having to remove the primary?
http://www.youtube.com/watch?v=6qIsr...ature=youtu.be
Thanks for any and all help!
Phil
Old 04-17-2012, 10:38 AM
BigJimmy's Avatar
BigJimmy
BigJimmy is offline
The linkage arm on the shifter shaft (opposite end from the shifter levers) is loose, broke, or stripped.
It has a tension screw that tightens the split to grab the shaft splines
Old 04-17-2012, 10:46 AM
skdvr's Avatar
skdvr
skdvr is offline
Thanks BigJimmy. I do believe you are correct. When I push it in it comes out a little from the back side of the linkage arm and then free spins inside. When I pull the shifter shaft out and it goes back inside all the way it catches correctly. I guess I am going to have to pull it apart and figure out if it is that linkage that is stripped or if it is the shifter shaft. I would assume that the linkage is softer than the shifter shaft so I would guess that to be the problem. I just have to see if I can scrounge enough tools to get it done at work.
Thanks!
Phil
Old 04-17-2012, 10:56 AM
BigJimmy's Avatar
BigJimmy
BigJimmy is offline
You just need some allen wrenches to get the linkage lever tight.
I had that problem on my '00 RK while on a long road trip. There is a split clamp with an allen screw to tighten it. On mine, the lever cracked opposite the split. I made some field repairs to get me home, but I had to replace the lever.
Old 04-17-2012, 11:04 AM
skdvr's Avatar
skdvr
skdvr is offline
I will try and tighten it down and see how it does. If not I will just take it apart and replace it. Got a PGR ride tomorrow for a KIA and I do not want to have to have a problem in the middle of 200 bikes.
Thanks again for the help.
Phil
Old 04-17-2012, 11:31 AM
elPrez's Avatar
elPrez
elPrez is offline
you can replace the shaft easily, mine stripped and I had the same problem.
Old 04-17-2012, 11:33 AM
skdvr's Avatar
skdvr
skdvr is offline
I tightened down the linkage lever and all seems to be good now. If I have any more troubles with it I will just take the shifter shaft out and see which is stripped. Thanks again for the help!
Phil
cwsharp
08-22-2022 11:54 PM
monkey sammich
06-15-2021 12:20 AM
Damien Morrissey
09-10-2019 12:49 AM
cfave
07-26-2013 07:48 PM
PDDGM
10-09-2008 04:42 PM
Quick Reply: 2005 Road King front shifter shaft
