Pro Pipe Quiet Baffle
Old 04-17-2012, 08:38 PM
hedgehorn's Avatar
hedgehorn
hedgehorn is offline
Default Pro Pipe Quiet Baffle
Has anyone installed the quiet baffle in a V&H pro pipe. I installed the pro pipe on my 09 EG and its pretty loud under a load or high revs. I had short shots on the wifes Cross Bones and installed the quiet baffles and it made them sound real tinny. Ended up putting the stock head pipes on and Rush slash cut mufflers. Does the quiet baffle on the pro pipe make it lose the deep sound? Thanks in advance.
Old 04-18-2012, 10:53 AM
joflewbyu2's Avatar
joflewbyu2
joflewbyu2 is offline
I heard it makes it sound bad. I pulled my baffle out and used muffler packing for both sections to quiet it down a little. There is a section with loose stainless wrap.
Old 04-18-2012, 10:55 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Vance and Hines "quiet" baffle will lower the sound by 2-3 DB and will give it a much deeper tone. It is my opinion that they sound rather tinny with the stock baffles.
Old 04-18-2012, 11:39 AM
jefla's Avatar
jefla
jefla is offline
I have an 09 SG w/ Pro Pipe, PC V, and SE AC. Dynoed after the install. Gonna try the quiet baffle. If I install w/o redynoing (to test sound) how off will the performance be? Will it run ok, just rich and a bit weaker? Worse? Will I mess anything up? How much HP & torque will I loose?
I'll post before and after data once I redyno.
Old 04-18-2012, 12:08 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
jcb1975@yahoo.com is offline
Every exhaust/baffle combination will re-act differently to each individual motor. Could be better performance, could be worse, only one way to find out.
Old 04-18-2012, 01:06 PM
XARAN's Avatar
XARAN
XARAN is offline
Ive used the Quiet Baffles in 3 V & H Pipes, on my 05 Fatboy installed QB in both a ProPipe and a set of BSS and on my Road Glide I have the QB in my 4" Black Out Rounds. On all 3 pipes I think the sound is a little deeper and on the Fatboy it helped low end Tq.
Old 04-18-2012, 07:09 PM
hedgehorn's Avatar
hedgehorn
Thanks for all your responses, I was not expecting to hear that it actually made the sound deeper. It sounds awesome with the standard baffle when going through the gears at full throttle. Its just a little obnoxious at freeway speeds for long periods of time. I think I will give it a try. Thanks again
Gordon61
Exhaust System Topics
05-17-2016 03:38 PM
TSD
11-22-2015 10:55 PM
yandeltx
07-30-2012 12:15 PM
JimmySG
05-22-2010 06:52 AM
turbo38sfi
05-06-2007 01:05 PM
Quick Reply: Pro Pipe Quiet Baffle
