Help Replacing 2009 FLHX Rear Fender with 2010+ Rear Fender
Hi all,
I just can't leave a good thing alone... I decided to refresh the look of my '09 Street Glide by replacing the rear fender with the 2010 rear fender. I know that the metal will fit just fine but my problem is the electrical stuff.
I already did a search in this forum, and others, but there was no thread with all the information needed.
Here is what I have, so far:
2010 FLHX rear render
2010 FLHX rear turn signals
2010 FLHX rear fascia with tri-bar run light (will be replaced with 2010 run/brake, part #67774-10, or use the 2009 that I have)
2010 Center-Mounted Auxiliary Run/Brake Light (HD Part # 68000029)
2009 FLHX rear fender with brake light, turn signals and wiring (on my bike)
2009 FLHX rear fascia with tri-bar run/brake light (on my bike)
My goal is to not cut any wires (if possible). I printed out the parts lists for both years for the the rear turn signals, fenders, etc. The problem is that they are a little confusing.
Has anyone done this conversion without cutting?
What other wiring parts do I need?
What do I need to do?
Any leads/information?
Thank you in advance for your help.
I would appreciate if you can send me the 2010 SG wiring diagram. I already have the 2009 diagram.
Thank you.
Also, where does the Center-Mounted Auxiliary Run/Brake Light (HD Part # 68000029) connect?
What is the fender wiring harness part number?
Does anyone have the FLHX rear fende harness part numbers for 2009 and 2010?
