1999 Ultra & fuel consumption
Old 04-22-2012, 01:08 AM
twistedcherokee's Avatar
twistedcherokee
twistedcherokee is offline
Default 1999 Ultra & fuel consumption
When I first got my 99 Ultra I got 50mpg 2 up. Now I am getting 37mpg 2 up. What all can I do to get it back up there? As far as I know the only real thing that can be changed is the TPS. I used a gas analyser & set it by the TPS & went from 1000-600 HC down to 200 at idle & 150 @2500rpm's. I tried setting up the TPS by the manual but that had the HC way up there. All the sensors were replaced new about a year ago. I have adjusted the valves a couple of times also. Moving the TPS just seems to be a lot from where the manual says to start. I don't want to run it lean is why I stopped @ the 200-150HC's. Anyone with any idea's
Old 04-22-2012, 06:41 AM
cochon's Avatar
cochon
cochon is offline
Whaaa?? TPS?? 1000-600HC down to 200 at idle and150@2500rpms??? I am sorry, but, I don't understand what you are asking!
Old 04-22-2012, 11:28 AM
twistedcherokee
TPS is throttle position sensor HC is hydro carbons. If you don't have enough fuel ot will run lean which can burn pistons, run hot. Optimum fuel ratio is 14.6, but since it is air cooled, I am not sure if it should have more fuel to help keep the engine cooler. That is why I adjusted the tps for the 200-150 (200 being at idle & 150 at cruise rpm)
Toby
Old 04-22-2012, 11:47 AM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
Just shooting from the hip but could be fuel related? Try picking up a bottle of Star Tron, an ethanol neutralizer. It is a shame we are forced to deal with ethanol. I just had a lawnmower serviced because of it. I also run some Techron fuel system cleaner through my bike from time to time.
Old 04-22-2012, 11:50 AM
sedouglas's Avatar
sedouglas
sedouglas is offline
I'd put money on fuel quality.
96 Ultra
EVO
29
08-01-2011 09:46 PM
Ratrods40
08-02-2010 09:14 AM
mkizer
Exhaust System Topics
06-29-2009 11:00 PM
96 Ultra
09-08-2008 02:14 PM
Tanker2
07-09-2008 07:47 PM
Quick Reply: 1999 Ultra & fuel consumption
