HD Rear LED signal lights with run/brake fender tip light
Anyone install the HD rear LED signal lights with the run/brake fender tip light? Looks like it was not intended to be compatible. The instructions assume you do NOT have the run/brake fender tip light. I think I will have to cut and splice the third wire going to the run/brake fender tip light. Any advice?
I noticed the same thing. I got the tailtip light that acts as a running like (stock) and as a brake light. It has a 3 rd wire that plugs into the middle of the plug in the brake light - same as the LED rear turn signal alls for. I heard the HD LED turns have had problems and decided to keep the stock bulbs. Don't like the idea of load equalizers wether separate or built in.
I installed the HD LED brake light, turn signals and fender tip light last year. Everything plugged in as per instructions. However the fender tip light did have that 3rd wire for brakes. I just spliced it in and all works fine. I never saw a post on this before and was wondering if I was the only one who had that issue.
I have the setup on my UC. The problem I had was there was'nt a place to connect one of the wires. I just tapped into the harness and soldered a connector in to make connection. I can disconnect everything and solved the problem. It's pretty cramped behind the tail light but you can still make it work.
lawnmower man
01-04-2010 02:02 PM
