2006 Ultra Classic Engine Cough
Old 05-06-2012, 06:07 PM
ConroeTxHarley's Avatar
ConroeTxHarley
ConroeTxHarley is offline
5th Gear
Default 2006 Ultra Classic Engine Cough
Bike has a stage 1 w/ download & hooker true dual pipes. It has what I call a cough or slite spit at the injection/ air filter sect. at low speeds,, at high speeds its great. Would a leaky intake/ exhuast gaskets cause this, like it would on a carburated bike?
Ive been looking at the dynojet power vision tuner, any suggestions would help! Thanks, Troy
Old 05-06-2012, 06:38 PM
dawg's Avatar
dawg
dawg is offline
Received 2,955 Likes on 1,711 Posts
A leak might cause that, yes. Have the injectors been replaced from the 8* to 25* injectors yet?
Old 05-07-2012, 01:07 AM
luisan's Avatar
luisan
luisan is offline
Hey Dawg,I have a 2006 Ultra with Stage 1 and SuperTrapp and it isn't showing any of the other guy's problems but I'm interested in the reason why you're asking if the injectors have been replaced from the 8 to 25.Is there a reason they should be replaced?Thanks
Old 05-07-2012, 05:39 AM
skydude426's Avatar
skydude426
skydude426 is offline
Some of the 06s had 8 degree injectors. They have been known to cause " drive ability issues". Mine had 8 degree injectors. Never really had a problem but I changed them to the replacement 25 degree injectors anyway.
Old 05-07-2012, 07:20 PM
dawg's Avatar
dawg
dawg is offline
The 8 degree injectors were problematic as skydude stated. Some folks' bikes had been known to cough and die in the middle of traffic, thus causing a safety issue. The remedy was to change them out to 25 degree injectors that HD came out with.
Old 05-08-2012, 01:01 AM
luisan's Avatar
luisan
luisan is offline
Would you suggest an injectors swap anyway even if my '06 hasn't been showing the problem?Would you have part #s.Thanks
Old 05-08-2012, 06:27 AM
skydude426's Avatar
skydude426
http://www.rbracing-rsr.com/downloads/hdinjectorswap.pdf
Heres a link to a PDF of the service bulletin that covers this problem. It has pictures of the two injectors and the part numbers.
Old 05-08-2012, 06:32 AM
dawg's Avatar
dawg
dawg is offline
I would swap them out anyway.
Old 05-08-2012, 09:15 AM
GMRO's Avatar
GMRO
GMRO is offline
IS there a way to tell which one you have in the bike? That is thru a visual inspection - part stamp on the injector?
I've a 2006 UCEG. No issues at all with the stage 1 on my bike. BUT wondering IF I'd notice an improvement switching IF the bike has the OEM 8's.
THANKS!
Old 05-08-2012, 04:55 PM
dawg's Avatar
dawg
dawg is offline
THANKS!
See attached
Quick Reply: 2006 Ultra Classic Engine Cough
