what does a "flash" actually do ?
Old 05-07-2012, 10:15 AM
rowle's Avatar
rowle
rowle is offline
Default what does a "flash" actually do ?
Hi All,
I know what all the air/fuel ratio gadgets do such as fuelpaks etc but what does a dealer "flash" actually do to my bike ?
Just putting some V&H hi-outputs on my 2012 EG and can't make up my mind whether to go fuelpak or flash.
Thans all.
Rowle - UK
Old 05-07-2012, 10:21 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
depending on which version used, the HD download will alter the ECM's response to sensor input.
If just doing pipes, you needn't alter anything.
If also doing hih flow air cleaner, you should look into altering the tuning.
I, like many others, use nightrider.com XIEDS- a $125 solution.
they are resistor packs which plug inline with the o2 sensors, under most riding conditions, they mixture will be made slightly richer.
fuel economy will be less affected than other units- I get about 43 MPG at 65~70 MPH ( and thats a US gallon, just under 4 liters- the UK gallon is 4.55 liters I think)
mike
Old 05-07-2012, 10:34 AM
longrideshields-1's Avatar
longrideshields-1
longrideshields-1 is offline
Premium Sponsor
Mike pretty much summed it up!
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old 05-08-2012, 05:15 AM
rowle's Avatar
rowle
rowle is offline
Thanks both,
i was thinking of going the Xied route and now i will - no programming to do !
thanks both.
Old 05-08-2012, 05:27 AM
mike5511's Avatar
mike5511
mike5511 is offline
I only read the title of your thread, and my answer is: puts a big ol' smile on my face!
O.K. I went back and read the whole thread. I think you got some good advice. I started out with the xied's then went with the SEPST tuner and dyno time etc etc. Now you can see below what I'm running. I often think that I should have just stayed with the xied's. But I do love the difference the cams made!
Old 05-08-2012, 05:52 AM
VTL nut's Avatar
VTL nut
VTL nut is offline
Originally Posted by rowle
Hi All,
Thans all.
Rowle - UK
A "flash" actually changes the data stored in (ROM) adresses of the ECM.
These adresses contain target data (shown numerically in table format with most tuners) which the system uses to make your scoot run.
Old 05-08-2012, 05:57 AM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
Thanks both,
thanks both.
Proper "progamming" will normally help even a completely stock bike.
Before spending the money, you might be better served by understanding what the "Xied" will and won't do.
TWewers
06-29-2014 08:57 PM
Jersey_Marine
05-05-2013 10:25 AM
TVil
08-28-2010 05:20 AM
txhdguy
04-17-2010 08:29 AM
Bobber Rider
07-09-2006 02:38 AM
Quick Reply: what does a "flash" actually do ?
