Replacing clutch cable for the first time - Harley Davidson Forums
P
Thread Tools Search this Thread
Old 05-10-2012, 06:21 PM
Henry89's Avatar
Henry89 Henry89 is offline
Senior Rider
Question Replacing clutch cable for the first time
I'm going to be replacing my clutch cable with a longer one when I install my 10" PYO bars. This will be the first time I've replaced a clutch cable on a HD so is there anything special I need to be aware of when installing it? I do have a service manual for my 09 SG. Thanks!
Old 05-10-2012, 07:10 PM
Hrlyrider's Avatar
Hrlyrider Hrlyrider is offline
yes don't cross thread it or tighten it too much. Put some lock tight on the threads and don't overtighten or you will ruin the rubber seal.
Old 05-10-2012, 07:14 PM
TUCCI's Avatar
TUCCI TUCCI is offline
Here's something that spoke volumes for me and answers a boatload of questions:
Pay close attention to the clutch cable replacement segment >
http://www.youtube.com/watch?v=ik73i5x3jdI
Old 05-10-2012, 10:13 PM
Henry89's Avatar
Senior Rider
I watched that vid last night. What I didn't understand was what was he doing under the derby cover on the left side?
Old 05-11-2012, 05:48 AM
Gunnysgt's Avatar
Gunnysgt Gunnysgt is offline
Just switched out the clutch cable on my SG when I put the 577s on. Simply take note of how the old one is run to the tranny cover. Follow the service manual directions, make sure the ***** are seated properly under the release arm. Adjust it according to the manual. The clutch inspection (derby) cover is removed to adjust the nut at the plates. That is all explained in the manual. Not a problem.
Old 05-11-2012, 05:55 AM
Henry89's Avatar
Senior Rider
Quote:
Thanks Gunnysgt! I'll read over the adjustment in the service manual.
Old 05-11-2012, 10:13 AM
4Fifteen1's Avatar
4Fifteen1 4Fifteen1 is offline
New Member
12" PYO bars, still using original clutch and brake cables. Clutch cable not ran through fearing though.
Old 05-11-2012, 10:25 AM
strippedthread1's Avatar
strippedthread1 strippedthread1 is offline
New Member
As said before, use your service manual.
You can remove the right side cover of the transmission without draining the tranny fluid by rolling both wheels up on a 2x6, 2x8, or 2x12. By doing this, the bike will lean over further on the kickstand and when the clutch cable cover is removed from the tranny housing you won't lose your fluid.
I have done this on several bikes without a problem.
Old 05-11-2012, 01:05 PM
ICIBUY's Avatar
ICIBUY ICIBUY is offline
Just did mine... twice actually. Dont try to do this without draining the tranny... friend of mine told me he didnt lose much fluid when he did his (think he was setting me up) you will have a huge mess on your hands! When you re-install the new cable... tighten the cable into the clutch release cover before bolting the cover back on the tranny and before you make the inner connections. The manual says to leave it loose, when I did this the first time I barely had it tight and the cable fitting snapped off into the cover! Leave the bolts loose until you have the cable/lever adjusted and then go back and torque the bolts and refill the tranny. The tranny holds exactly one quart. The first time it took me about 2 hours (removing exhaust is 20 minutes for me) the second time it was less than 60 minutes.
Old 05-11-2012, 01:18 PM
Wanna Ride's Avatar
Wanna Ride Wanna Ride is offline
You've already done the smartest thing you can... bought the manual.
Just recently installed 10" Monkey bars on my StreetGlide as well. I also installed a new ss/chrome cable. It's the same length as the stock cable, but I just wanted to add a better looking cable to the whole handlebar mod. If you have any questions at all, feel free to PM, and I'll be glad to help you through it. Not very difficult at all, just remember the fundamentals of tearing it down and swapping out parts; don't over-tighten fasteners, make sure mating surfaces are clean, and pay close attention to how everything goes together before you tear it down. Take pics with your phone as you go (from several different views), so you can refer to them as you put it all back together.
Clutch adjustment. Just watching that segment alone doesn't really offer much info. The HD manual does a pretty good job of explaining this segment. It's been a while since I watched that entire video, but as good as it is, it's not the end-all/be-all. I can't remember if it details the segment of installing a NEW cable into the trans case.
Gunny mentioned the *****, that's a good note. also be sure to orientate the internal snap-ring properly when you put it back together. Thoroughly read/comprehend the clutch adjustment segment, and you'll be fine. Just a bunch of little details that will insure success. Again, don't hesitate to pm me any specific questions. Good luck!
P
Thread Thread Starter Forum Replies Last Post
Adjusting Clutch Cable - What Broke? rdondes Dyna Glide Models 6 10-23-2013 08:16 PM
Magnum clutch cable questions cmosentine Softail Models 6 08-26-2013 09:49 AM
Clutch cable Elwood87 Dyna Glide Models 4 02-04-2013 04:50 AM
clutch cable install question sledhead140 Touring Models 4 02-24-2011 01:01 PM
Clutch Cable Install aviscomi Softail Models 16 08-31-2008 11:08 AM
Tags
brake, cable, cables, changing, cluch, clutch, davidson, glide, harley, installing, replace, replacement, replacing, street, tightened
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
