Tour pack lights found on EBAY?
I added them because the two turn/brake lights thats the 10 and newer steet glides have were not being noticed enough by my riding buddies all the time when I hit the brake. They said they wouldn't notice because they were either both dim or both bright un-like when turning where one is blinking and the other in not. So having an extra brake light on the tour pack that is also closer to eye level helps for safety knowing that I have a better chance someone behind me either car or bike sould be able to see my brakes better when I have the tour pack on. And because I think they look cool! Still waiting on the modules to make all three sections of the rear light work as a brake and to make it work as a urn signal, and also the one to make my side marker lights work as turn signals. After I get it all installed and working I'll get some photos up. Theres a video on youtube of what I'm looking to accomplish.
http://www.youtube.com/watch?v=ERgK_PGyu9U
Same thing I just want my side markers to blink as well. And I'm digging the painted led light trim, that might be in my future?
So do the Ebay lights (side maker lights) have dual intensity? I noticed that only the middle light is used as a brake light.
I believe you need to buy something like this as well. I have it on order just waiting for it to arrive.
http://www.ridetimetechnology.com/tp_seultra.htm
I ordered the TurnSE+ Module and
http://www.ridetimetechnology.com/flashr.htm
for the side markers.
Just an update, I recieved all my Ride Time Tech products and have not been able to get them to work properly. I HAVE NOT contacted the company because of a busy time line at work and I'm sure it has to do with the 2010 and newer street glides not having a center tail light and must have a stock run/brake/turn module for the two bullet brake turn lights on my street glide. The RTT web site states you must wire before any run/brake/turn module but I'm not sure were it is on the 2010 street/Road glides? Anyone have any ideas where to look? Ive looked all around the fuse panel and found the side marker lead to power my side markers and found the main light harness that has the turn leads that work correctly with a electricity checker but once I connect the modules they light up and none of the turn break features work. I'll call when I get time but thought I would ask here first to see if anyone has already asked or ran into the same issue and found the solution already.
Thanks, and I'll post some pics when I get finished and can post a pic of the lights with the dim sides and center and then the bright center when the brakes are applied if anyone cares to see what they look like when you wire up the lights oppisite what the directions call for.
