Tour pack lights found on EBAY?
#31
I looked at a real CVO Ultra at my dealer and turned on the lights. The chrome LED light bar on the tour-pak works as follows: center section is running light and brake light. Outer sections are running light only.
The eBay copy works differently: center section is running light and brake light, like the H-D light. However, outer sections are BRAKE light only (not running light like H-D).
My point is, if the Ride Time Technologies unit is designed for the H-D light specifically, that could explain the problem using it with the eBay light??? Just a thought.
#32
Those that wish to make the outside lights on this tourpack light kit work as a brake / turn lights. The kit from Harley that works for the stock Ultra tourpack WILL WORK with this light bar. I installed it on mine and all the lights come on when brakes are applied and the outside lights works as turn signals also. The center light stays the same, works as a running / brake light.
I don't have the HD part#, but if I can find the box, I will post the part#. Again this kit is for the tourpack only.
#33
And the ebay cheapo can be wired to act as dim or bright corner lights and a dim/bright center brake light. If you wire the lights like the picture on ebay your corners will be bright, if you reverse the wires the corners are dim and match the center brake before the brakes are applied. I assumed the corner lights might act like the side markers with the ride time modules that just turn the lights off and on no dim and brighter. But I can't even get the side marker blinkers to work.
#34
The issue I'm having is that I have a 2010 street gilde that has a different main harness than the ultras have(New street gides have a round connecter under the fuse box and the ultras have a square connector near the rear fender). The Street glide doesnt have the middle third brake light any more and just has the two bullet run/turn/brake lights that have to have a module located somewhere on the bike, just can't find it to wire my ride time modules before the stock one.
#35
I used the HD tour-pack light conversion kit part# 69200042A for my RG. I'm not real sure about the difference in the connectors between the SG and the Ultras. But this kit comes with a flasher module assembly that should work. The kit says that it makes the outside lights work as running/brake/turn lights, but with the LED light bar, the side lights work only as brake & turn and the center light is run & brake. Which was OK with me. As for wiring, I did have to hard wire some of it because even my RGU harness didn't match.
Cep
#38
#39
circuit
Ok everyone i hope i can clarify a few things so i'll go step by step.
1. You need the following (4) diodes # IN4007, (2) 150 Ohm resistors and some 18 gauge wire. I used some wire i have for other projects. to keep things easy i used the same color code HD uses blue for run and red for brake (or turn).
2. Diodes are one directional and current will flow in one direction. Solder a diode with silver line towards the resistor (see pics). then Solder the diode using a blue wire, this is now your running light wire.
3. Solder the other diode to a red wire, this is now your turn (or brake) light wire.
4. Solder the resistor end to the diode end (see pic 4 and 5).
after you solder them, you can use heat shrink to insulate the wires from gounding out.
#40
