Where is the air temp sensor
I'm installing the oil temp gauge and it says disconnect the air temp sensor and plug in the oil temp harness. I can't find the sensor on my 2012 Street Glide.
EDIT:
Found it in this thread.
https://www.hdforums.com/forum/touri...ere-is-it.html
EDIT:
try looking here.
I am not sure if the 12 street glide is the same but on my 2012 limited was located on the left side of the sterring neck. You can slide your hand along the frame toward the front and it is a small black plastic peice riveted to the steering neck or just before the neck. It is about 3/4" by 1/2" box...if I remember right...might be a little smaller.
