Replacement Bulbs for Front/Rear Turn Signals?
Old 05-19-2012, 06:57 PM
FenderGuy53's Avatar
FenderGuy53
FenderGuy53 is offline
Default Replacement Bulbs for Front/Rear Turn Signals?
I have a 2011 SG and as we were riding today, my buddy pulls up alongside and tells me that my left rear running light is out (but my turn signal and brake light were still working).
When I got home, I pulled the burnt bulb and it has writing which reads: 198 12V32/3CP
I looked in my Owner's Manual, to no avail, for the bulb specs.
My front/rear turn signals are the bullet style with amber lens in front and red lens in the rear. The bulbs are clear.
What replacements bulbs do I need for the front/rear turn signals on my SG?
Thanks, guys!
Old 05-19-2012, 07:15 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
I am not sure if there has been a change for 2011 but this is what I use on my ’08:
Front 1157A
Rear 1156A
“A” is for amber so if you want clear look for them without the “A”. You can also find them with “LL” for heavy duty.
They are a common bulb that you can get from Wallmart or auto parts stores.
Old 05-19-2012, 07:17 PM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
just go to your local auto parts store or wal mart and say here I need one of these , front may be different take one of them to
Old 05-19-2012, 07:19 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
Front 1157A
Rear 1156A
Why don't you upgrade to LED equivalents. Your bike would look great with smoked lenses and bright LEDs (red bulbs in the rear).
Old 05-19-2012, 07:28 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
They are just common automotive bulbs.
Old 05-19-2012, 07:59 PM
jjnoble's Avatar
jjnoble
jjnoble is offline
Thanks, guys!
I had a front one go out last week. I forgot all about it. Thanks for the reminder.
Old 05-19-2012, 09:35 PM
Arizona's Avatar
Arizona
Arizona is offline
Is the main rear tail-light/brake light also 1156? And the two rear turn signal/tail lamps are 1156 also? In other words all three in the rear are the same? Thanks, I have the H-D numbers for these parts but obviously on the road at Walmart the common bulb numbers is a great idea to know.
Old 05-20-2012, 09:30 AM
FenderGuy53
I went to Auto Zone yesterday, burnt bulb in hand, and this is what I found for my 2011 SG:
You need dual filaments in the front/rear because the front bulb serves as a turn signal and running light, while the rear bulb serves as a turn signal, running light and stop light.
The physical bulb size/shape, alignment pins and contact points match up perfectly with the OEM bulbs.
FYI, I bought the 1157LL 2-pack because it's a long-life bulb.
Thanks, guys!
Old 05-20-2012, 10:06 AM
b17467's Avatar
b17467
b17467 is offline
I was asking the differance between the 198 and 1157 a while back and someone gave me this info.
https://www.hdforums.com/forum/8565003-post5.html
I just went to Napa and picked up a few there.
Old 05-20-2012, 07:43 PM
FenderGuy53
The 1157LL's will work just fine - and consume less power at the same time.
Quick Reply: Replacement Bulbs for Front/Rear Turn Signals?
