I just activated the XM radio on my new Zumo 665 Road Tech. The reception is quite poor. Only 1 bar and it cuts in and out. XM radio is basically useless right now. Dealer installed entire unit including the NIM and antenna (puck). Before I take it back, I wanted to check with you folks to see if anyone else has had this problem and if there is something I can do?
Do you know where the antenna puck was placed? I have the regular Zumo 665 on my Ultra-Classic with the puck sitting on top of the radio inside the fairing (it's magnetic). Satellite reception is excellent.
Thanks
I agree with everyone else about the antenna position question. I'd pull the fairing cap off and have a look. If you never done it before It's pretty simple and a 10 minute job. You can place a towel across your front fender and leave the head light harness connected when you pull the fairing forward. Just let it rest on the fender while you have a look.
I put double stick velcro on the puck and attached it to the top of the front brake resivior, wrapped the cable down the handlebars and into the antenna connection.
