crank sensor 99 king
Old 05-24-2012, 08:31 PM
kjay's Avatar
kjay
kjay is offline
Default crank sensor 99 king
hi all, i have 99 road king classic. looks like i need to change crank sensor.
i found the sensor, follow the wires looks like it conect to a wire harness under the fram rail. looks like i have to remove pins in the harness in order to install the new sensor. does anyone have any sugestions how to go about this?
Or would i be better off cutting exisiting wires and solder onto new sensor leads. i do have harley shop book cant find it in there. any help would be appreciated
Old 05-25-2012, 12:27 AM
twistedcherokee's Avatar
twistedcherokee
twistedcherokee is offline
They are easy to change, you have to pull out the keeper then use a pick & move the pin lock & it will slide out. Just make sure that you make a diagram with the wire colors for placement when you put it back together. I think the owners manual has some pics on how to do it. Good luck
Toby
Old 05-25-2012, 07:42 AM
kjay's Avatar
kjay
kjay is offline
thank you so much for your help. after you got me pointed in the correct direction, i found more information on page 400 of my clymer book.
i am of little use to most on here with my limited knowledge but thought least i could do was post that information incase it helps someone. book tells me its called a deutsch connection.
greatly appreciate the help.
cubalz
11-07-2016 08:38 AM
dusturbd
11-17-2013 12:23 PM
Cajunsurfer06
10-01-2012 08:08 PM
davidkidd
Electrical/Lighting/Alarm
04-19-2012 07:06 PM
Jerzmatic
02-07-2011 05:30 PM
Quick Reply: crank sensor 99 king
