Flag Mounting help needed.
I know there are many threads out there for mounting flags (large ones) to the support brackets and lower portions of a bagger.
I am hoping someone knows where I can find one that mounts to the luggage rack or the like that allows me to fly a 3x5 flag. I know the most common style for this part of the bike would be a smaller flag, but I want to mount a 3x5!
I am stationed overseas and will be enjoying the 4th on post with other riders. If you got any idea, I could use the help!
This is a very high quality product. And fine folks there as well
http://www.rivcoproducts.com/products/home.php?cat=433
Location: Western Illinois, land of bad roads, and corrupt politicians
I keep forgetting to get a picture of the finished product. This was still in the construction phase. The beauty of using a detachable backrest is, it can be installed/removed in a few seconds.
Passenger rest, without the pad. Some aluminum plate (2 plates per mount). Don't ask where I got the extruded fittings.... I don't remember ("U" bolts would also work)
I have run this thing at 80 mph with no problem. The pole is PVC, with an aluminum tube, and an oak dowel inside. I run a 3 X5 50 star cavalry guidon flag. Similar to this except for the stars http://www.carrot-top.com/media/cata...guidon_1_1.jpg ...... the notch allows the flag to cut through the wind easier....... old cavalry trick to keep the guidon bearer from getting thrashed around by the flag riding in a full gallop charge. The notch also helps to keep the flag from doing the loud SNAP, and helps to keep it from shredding at highway speeds.
The view from the back
The view from the front (towards the rider) If you want to have a passenger, you will either have to figure out a pad..... or just have a really pissed off passenger.
That's a very good point. Luggage racks are rated at somewhere around 15-20 lbs capacity.
That's why I use the passenger backrest. If one of those can support a fat chick, it should hold a flag.
OldDrummer55 (07-01-2020)
