oil change how to
Old 04-03-2012, 09:06 PM
rhaneski's Avatar
rhaneski
rhaneski is offline
Default oil change how to
Im sure its been posted, but I didnt see it in a search.
Amy how to's for an oil change on an 08 Ultra classic with oil cooler.
Thanks
Old 04-03-2012, 09:19 PM
jackhis's Avatar
jackhis
jackhis is offline
Open your owner manual, or bring the bike to the dealer.
Old 04-03-2012, 09:21 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
The oil cooler is a non-factor. Get a service manual and you will be fine. Just remember to short fill when you replenish the oil and add to the stick, Never just dump in what any manual tells you is the capacity of the oil.
Old 04-03-2012, 09:23 PM
Joboo1966's Avatar
Joboo1966
Joboo1966 is offline
Here's the link it's for the 2007 but it's the same method.....the oil cooler is a non factor you need not touch it to do a basic oil change. There are purge kits that allow you to purge the old oil from the lines through the cooler and the engine but even Harley Davidson does not do this when they change your oil as the small amount of oil left in the system ( less than an eighth of a quart) will make little difference in the grand scheme of things, although it is touted as more signifiicantly usefull in bikes older than eight years old. Since yours is an 08 follow these instructions and you'll be fine. I love it when people ask for help and smart asses take the Time to be ignorant , and go so far as to post nothing but sarcastic " open your manual" or take it to your dealer"........maybe he does not have the book, or maybe he doesn't wanna pay Harley 100 bucks or more to perform a 35.00 job, in any case offering answers of significance and substance will go much further in not only helping the brother out, but in keeping people comming back to and using this forum. And people wonder why new folks come here for help then never come back. Im not refering so much to qtracer as he had at least some advice of substance, but the other poster, would have better served you by not posing at all. Jeesh!
Rhaneski , I'm sorry , you can count-on getting at least three out of five ignorant responses to every post This usualy means they probably don't know the answers or are unwilling to go the extra mile to help out a Harley brother in need. I'm ashamed on their behalf. I'm sure they're not.
http://www.ehow.com/how_7708367_chan...ic-harley.html
Old 04-03-2012, 09:30 PM
Jeffs386's Avatar
Jeffs386
Jeffs386 is offline
If you decide to change the tranny oil I suggest Spectro Platinum 6 spd...its expensive but the difference in shifting smoothness and lack of clunking makes it well worth it in my opinion
Old 04-03-2012, 09:33 PM
cromagnon's Avatar
cromagnon
cromagnon is offline
I usually just grab a wrench, loosen the drain plug and let the oil drain into a pan. If you remove your dipstick, the oil will drain faster. Remove oil filter and spill oil all over the floor. Put drain plug and new filter back in. Pour in 3 quarts, put dipstick back in, start it up, run it for a minute, turn it off and put 3/4 quart in.
Dump a bunch of speedy dry under bike to clean up all the dirty oil you spilled. Bring bike outside, spray some de-greaser like bike bright down around the filter and front motor mount and spray that **** off. All done.
Now next time you can try and figure out some way of not spilling that shitty old oil all over your garage floor.
See, no video or manual needed.
Old 04-03-2012, 09:55 PM
Joboo1966's Avatar
Joboo1966
This was basically the short version of the link I posted minus the colorful metafors, but he posted the answer....my faith slowly returns.
Old 04-03-2012, 09:57 PM
Joboo1966's Avatar
Joboo1966
Good post! The stuff works great haven't heard the "clunk" once since I used it! I agree completely !
Old 04-03-2012, 10:00 PM
cdroundy's Avatar
cdroundy
cdroundy is offline
LOL...This is a great write up. Thank you for putting a comedic spin on a very mundane task.
Old 04-03-2012, 10:54 PM
Joboo1966's Avatar
Joboo1966
Amen!
Quick Reply: oil change how to
