Front Fog Lights
Front Fog Lights
I recently purchased a 2008 FLHTP Police Commemorative Electra Glide. The fog lights were not working so I took it into the shop. I was told whoever installed the aftermarket stereo used the switch from the fog lights to power the stereo. They said they had to order a new wiring harness. I guess the commemorative special doesn’t come with a stereo.
Then I was told the wiring harness they received was the wrong one. Does anyone know if there is a different wiring harness for an FLHT Standard and an FLHTP Police Commemorative Electra Glide?
Also, the siren and pursuit hand controls come on that model. Will I be able to replace those with chrome or am I out of luck.
Yes, the pursuit switch is for the "pursuit" lights on the police model (a/k/a "Passing lamps" on a civilian bike; not "fog lights.") Typically, the wig-wag switch for the pursuit lamps is removed and the red/blue pursuit lamps replaced with civilian lamps.
The best "accessory" money you will spend will be to purchase the HD Touring Model service manual and police supplement for your bike's model year; especially if you're going to do anything electrical on the bike.
Carl
Carl
Pursuit Lights
Thank's Carl,
The shop got back to me just this morning saying they fixed the problem. It had to do with the pursuit switch. When they got it to finally work and activate the "pursuit lights," they started flashing, which made them laugh. The mechanic rewired the lights with a new module and now they are fully operational passing lamps which work off the pursuit lights switch.
It took the mechanic 12 hours of labor to figure it out, but he did it...Great work by Mechanic Wayne at Back Alley Motorcycles in Temecula California...
Did HD originally wire those bikes to have operational passing lamps that work off the pursuit switch?
Oh! thanks for the nomenclature lesson, I would have sounded like a dork calling them fog lamps.
Your the man Carl,
Thanks'
Mark
Your the man Carl,
Thanks'
Mark
Mark,
Glad the tech figured it out. It's tough for indy shops to have the HD police manuals; if he'd had them he'd have seen in the wiring diagrams the switch which makes the passing/pursuit lamps wig-wag and it would have saved him a ton of time removing/by-passing it.
Enjoy your FLHTP.
Carl
Enjoy your FLHTP.
Carl
