Transmission Fluid Leak
My wife's bike has trans fluid leaking down the clutch cable. I tightened everything up I could think of and it still leaks. It's not a lot but enough to be an issue. We did have new bars put on a couple of years ago with a longer clutch cable if that helps.
Any ideas?
Any ideas?
I just had the same problem. I bought the bike second hand, knowing there was a very minor oil leak. After cleaning, and a lot of searching this forum, I traced it back to where the Clutch cable goes into the tranny. The last person that owned the bike, had put apes/cables on. I tightened it up, but still leaked a little. I pulled it apart, and replaced the oring. That solved it. Hasnt leaked since.
cheers,
kyle
cheers,
kyle
My 07 is the latter and has been doing it since it was about a year old.
1.) check the tranny end cover bolts, the revised torque spec is 25 ft lbs.- esp the lower 2 bolts which on many models support the exhaust. ( this is quite common) the allens can be tightened by using a 1/4" drive screwdriver bit- put the bit in the allen head butt end first.
then turn the bit with a open end wrench.)
2.) check the tranny vent, mud dauber wasps have been know to clog this up...the pressure has no where to go but push past a seal. ( so leaks when running/ dry when parked)
3.) and as above, clutch cable seal or the clutch cable itself
oh and to track down the source of a seep, spray the suspect area with drugstore spray on foot powder.
the seep will wash it away
mike
mike
YellowHawk
03-13-2016 07:41 PM
