Code PO562
Old 06-10-2012, 07:43 AM
mwegnor's Avatar
mwegnor
mwegnor is offline
4th Gear
Unhappy Code PO562
engine light and battery light coming on in shop now but cant sem to find problem
Old 06-10-2012, 07:50 AM
ultrawarrior's Avatar
ultrawarrior
ultrawarrior is offline
I had engine and battery light on last week code was for low voltage, checked battery and tightened up on battery terminals. No problems, about 400 miles since.
Old 06-10-2012, 07:59 AM
mwegnor's Avatar
mwegnor
mwegnor is offline
4th Gear
Thanks I have checked all of that thing has drained my battery twice hope they fing out something tomorrow it only has 900 miles on it
Old 06-10-2012, 09:57 AM
Northbound Southerner's Avatar
Northbound Southerner is offline
Since you only have 900 miles, I bet it is a 2012. Your voltage regulator is going out. This is a known problem on 2012 bikes. If the dealer has never heard of this, they are really small or lying...Tons of threads on here. Do a search...
Old 06-11-2012, 07:44 AM
mwegnor's Avatar
mwegnor
mwegnor is offline
4th Gear
Every thing has checked out on the voltage regulator and stator they are calling harley today
Old 06-11-2012, 07:55 AM
Quiet56's Avatar
Quiet56
Quiet56 is offline
Mine would do it when I had been stuck in traffic. Once I got rolling again the lights would go off and everything would work fine. I was suspected the VR was getting heat soaked sitting right above the oil cooler and shutting down. I took it to the dealer and they tried and failed to get it to do it in the shop until they put a heat gun on the regulator and it shut down. They replaced it and I haven't had any problems since. (still crossing my fingers)
I'm over here in the desert and my scooter is in storage at the dealer so I can't put any miles on her again until I get back home around Christmas.
Old 06-11-2012, 09:45 AM
mwegnor's Avatar
mwegnor
mwegnor is offline
4th Gear
Thanks I will pass this on to my dealer
Old 06-16-2012, 06:53 AM
mwegnor's Avatar
mwegnor
mwegnor is offline
4th Gear
Thanks Everyone got new VR seems be doin great
Old 09-06-2015, 10:19 AM
jimroe's Avatar
jimroe
jimroe is offline
Stage I
Default harpo
we were out riding a lot of stop and go on the way home saw the check engine and battery light on and volt meter was on 12 volts drove it to the dealer and shut it off waited for the service advisor to come and went to start it and lights are out and charging about 14 volts drove home 45 miles and never came back on
fettnersa
09-01-2012 05:10 PM
leepetersusn
08-22-2011 07:26 AM
dogit56@aol.com
11-27-2009 12:13 AM
tekeum
09-23-2009 04:42 AM
SpiderPig
07-15-2008 11:24 AM
Quick Reply: Code PO562
