Garmin 655 XM Antenna location?
Just installed a Garmin with the XM. I have the antenna under the faring and have horrible reception. When I move it to the outside of the faring It improves dramatically. Where do you guys have yours. On my other bike I have the XM module and the antenna is under the faring and the reception is great. Hell this antenna from Garmin is twice the size as the one from Harley for the XM module for gods sake!
OK, Now for the update of my Dumb A$$ moment. I just realized that I had installed a matting to the inside of the outer fairing for better sound. Once I removed this matting that was over the XM antenna area, no more reception issues. Thanks for the reply's guys. I hope this will help others not to repeat a "NO SH T" moment!
Hey guys, I just bought the Garmin with the XM and the reception is very poor. I'm told its mounted under the fairing, no mention of it mounted on top of the radio under the fairing. Will my fancy chrome windshield trip cause no reception. That piece looks nice on the bike but is the metal causing the reception problems. Or does that huge pancake size antenna need to be moved to the top of the radio under the fairing?
karen
karen
I taked to the dealer and they are mounting the antenna's on the radio. Now the process of figuring out if the antenna is bad, connections, for my only chrome fancy trim piece is blocking the signal. I can get the signal for a while then its gone never to return. I rode west one day and it worked for almost a 100 miles on two lane rodes, but that is the only time its worked for a period of time. Mostly it works for about a minute then off, no signal.
This is the 3rd bike I've had my HD X-M mod in (I keep transferring whatever I can from bike to bike).
The X-M worked fine with the antenna installed inside the fairing.
Then on this bike the SE FLHX it was useless dropping the signal all the time.
I moved it to the outside and it has been flawless ever since.
I moved it to the little shelf between the windshield bags:
Is the antenna different from the pancake one in the 665 kit or the smaller one for the XM H-K mod. The size is different but are the antennas different. Garmin has told my dealer that mine either works or it doesn't work. Sometimes it comes on and plays for a minute, goes off and might not come back on. Then it may come on and work for a few miles then go off again, and will not show a signal.
So, does this mean the antenna is good, but has a poor line of sight? or does the antenna need to be replaced.
