Bagger wobble???
Received 47,744 Likes
Not at all! .... Sweepers and winding roads are a great deal of fun ( and very do-able ) on a bagger if all is set up properly ... my wife and I recently spent a lot of miles in North Carolina ( I've ridden in 46 of the 50 states ) and damn near wore the side walls off my 09 FLHTCU .... and believe it or not, one of her first comments was "This barge is a lot more friendly in the corners than the old bike ( a 1992 FLHTCU ) ... Granted it's not a canyon carver or a crotch rocket, but the new chassis are a WHOLE LOT better than the old units ... You might want to take "grbrown's" advice and loosen up on the bars a bit .... be careful not to grind off the floorboards Brother!
My bike did it for the first time yesterday on a long sweeping turn i take regularly take at speed. Yesterday i got smoked by a guy on a dyna
From the light he pulles a wheely midway through intersection and is gone. I caught him as he slowed for turn. I slowed to 90 and entered. A cross wind was blowing at a good clip and i backed off till the wobble stopped at 80. I picked it back up past the apex and rolled back on. I noticed te dyna was wobbling too when i passed in the inside lane
I didnt have any more wobble up to triple digits after that.
You don't need tru track on a 2009 and later frame. Leave your 2011 alone! I've got over 10,000 miles on mine and there is NO WOBBLE at any speed in any conditions. I ride the hell out of it throught the twisties, on sweepers, on the highway. Don't fix it! It ain't broke!
I run metzeler tires front and rear, the higher the tire pressure the better it seems to handle. I usually run 48 psi in the rear and 46 psi in the front. It handles the best at those pressures. as for not needing a true track I have one and I did notice the bike feels a lot tighter in any riding condition. Wondering if I should have went with a glide pro kit instead.
Jay
Jay
I have ridden the turn that i experienced the wobble on yesterday many times solo and 2 up at the same speed and never a wobble. With and without my yaffee bars and with amd without the agitator wheels. Not sure what caused it. I did notice the forks flex a bunch when i bump a grip with my palm firmly, both parked and moving at slow speed. I have new bearings and ohlin 6 Shocks from howard
added: I haven't experinced any wobble in tight twisty conditions, but I have during high speed sweepers, it's not all the time, but it's happened to me before (more than once) and never at the posted speed limit. Throttle input seems to make a difference in making it either happen or not happen and getting through it safely.
This is an older frame, but I still don't believe it 100% cured on the newer bikes, 100% better yes.
http://www.youtube.com/watch?v=Gmw6QppXnEY
