Electra Glide Gas Tank Venting Question
I purchased a 2003 Electra Glide a few month ago. I went for a ride the other day and it was around 96-98 degrees out, when I got home my bike was sitting in the garage next to us while I was working an a buddys bike. We could hear a hissing sound comming from my bike. I though it was my tire or rear air shocks leaking and proceeded to remove the bags to dig further. Turns out the sound was coming from a vent tube that comes out somwhere behind the side cover (or close) and goes up to the gas tank. I removed the fuel cap and the sound stopped. When I put the cap back on the sound started again an lasted for a while. Is this normal or should I be concerned that this is not venting properly. I have other bikes and do not recall this sound or them venting like this.
I have never heard my bike hiss, but if you were not venting properly, you would stall. I had a stalling problem, and it turned out that my vent tube was pitched. I was messing around under the seat and accidentally pinched the tube closed..
If I were you, I would check and make sure its not pinched and just allowing slight flow out of it causing the noise, kind of like when you make a balloon whistle.
