Primary oil change help ...
Ok doing a full oil change on my bike, 4 quarts in the engine about 22 onces in the tranny and poured the quart in the primary but the oil looks low in the primary?? Question can i add some on my engine oil or some tranny oil in there to bring it up. Book said 32 onces in the primary. Bike is a 2006 Elctra Glide. This is a Redline oil change.
Thanks
Steve in Ct
Thanks
Steve in Ct
I have a 2006 FLHR.
I never put more than 1 quart in the primary.
I put 22oz in the tranny.
I put 3 1/2 quarts in the motor.
I start the bike, check for leaks, let it idle for a while. shut it off and check the dipsticks on the tranny and engine for proper levels.
Are you using redline 20w50 in all three holes?
Not sure what weights the Redline comes in....but I wouldn't put gear oil in the primary.
I would put in 3 and 1/2 quarts in the motor then check the dip stick with the engine warm. There will be about 1/2 a quart of oil in the engine that will not drain out. Many here complain about oil blowing out the air intake when they put in 4 quarts. Yours may not do that but if you find oil in your air filter after putting in 4 quarts that will probably be the problem.
I have never tried the product in the below video but it looks interesting.
http://www.youtube.com/watch?v=6k3fRk-i9G8
http://www.youtube.com/watch?v=7Ci9_915qYA
Steve in Ct
FBFletch
Oil Archive (no new posts)
06-08-2006 01:20 AM
