Issues with TBW on 2009 Ultra
If I twist the throttle on my '09 FLHTPI too far closed, ie past the normal 'stop' I get weird electrical things happining, criuse light comes on, I don't have cruise, check engine light and code for TBW. I find as well, if I blip the throttle just before shut off, it will idle high the next few starts. If this happins, you can turn the switch on and off 3 times to reset the idle to normal. I now am careful to not twist below the normal stop, and the bike is fine. hope this helps.
The dealership replaced all the pins, which is what HD tech told them to do. I haven't had the throttle cut out since but I have been having a serious throttle lag issue. I start off, in 1st, or try to accelerate from low RPM, 1600 or below, and it coughs, sputtered, bucks and then takes off (or stalls). The other thing when I got it back was that all my tuning to the SERT was gone and I think the SERT went into test mode.
Anyone else have the throttle lag (hesitation) issues?
DaveHead
06-29-2014 04:58 PM
