front brake poporting valve brake bleeding problem
i run a porshing valve teed off my rear brakes that runs to one off the front brake calipars. when it hit the rear brake pedal it works both front brake and rear.
i have and double banjo bolt in the rear brake with 2 lines one goes to the rear. the other goes through the adjustable valve then to the front brake calipar.
i have run this set up for years . the trouble is i cant get it to bleed. have push fluid through both calipars , and tried suction as well. the rear is fine its the front calipar.
any ideals ?
thanks for the help.
any ideals ?
kingironhead
07-15-2014 03:01 PM
