Sounds like exhaust/head gasket leak
Old 07-05-2012, 06:03 PM
Yukon42's Avatar
Yukon42
Yukon42 is offline
Default Sounds like exhaust/head gasket leak
Have a 103 with rinehart true duals, harley heavy breather and S&S 551 easy start cams (about same as 255's). Prior to installing the heavy breather and cams everything sounded just fine. However, now, only when the engine is under load, I hear a sound similar to exhaust leak or head gasket leak. I've used the "hose method" to try to locate the source but to no avail. I was leaning towards the exhaust gaskets, but I've changed them out twice and still have the weird sound. Now I'm wondering if it may be caused by the heavy breather/cam combination. Any thoughts????
Old 07-05-2012, 06:48 PM
Softy 103's Avatar
Softy 103
Softy 103 is offline
Just put a Heavy Breather on my 2012 FLHX, I know the sound and I think the noise is coming from the breather I'm getting used to it. Going to try one of those slotted covers and see if that helps.
Old 07-05-2012, 06:52 PM
TSD's Avatar
TSD
TSD is offline
My bike has the exact same sound and I have replaced everything on the exhaust. Sound still there and I have basically the same breather with the stock cover. I have finally gotten used to the sound.
Old 07-05-2012, 07:22 PM
Spinner18's Avatar
Spinner18
Spinner18 is offline
If you had an exhaust leak or head gasket leak, you'd see oil leaking from somewhere... I did true duals on mine and same sound came, sounds like rear cylinder. Just ride it
Old 07-05-2012, 08:52 PM
wrenchguy24's Avatar
wrenchguy24
wrenchguy24 is offline
You are hearing the air cleaner sucking air!!!
Its normal with that style cleaner
Old 07-06-2012, 10:00 AM
Yukon42's Avatar
Yukon42
Yukon42 is offline
Thanks for all the opinions. As there are many with the same sound, it is apparent it is normal for my configuration. I guess I won't worry about it and find that I am getting used to the noise.
Old 07-06-2012, 10:22 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
I've got the SS stealth breather and I don't have any sucking sounds or anything coming from my breather.
Old 07-06-2012, 10:31 AM
Airborne350G's Avatar
Airborne350G
Airborne350G is offline
The design of the cover must help with the noise on the stealth AC.
shankman
03-22-2017 09:09 PM
blazemate
08-14-2015 02:02 PM
Fathertime500
07-14-2014 12:15 PM
12hdrk
12-07-2013 10:06 AM
hcruz
10-23-2007 05:17 PM
Quick Reply: Sounds like exhaust/head gasket leak
