Need some help from those who have swapped out this mod. What I am attempting to do is install this without removing the rear wheel. I know it can be done but can't find the tool for the job. What do I need?
You don't need to remove the rear wheel. It's just the two bolts and pull the wires through. You will need to disconnect them from behind the tail light and feed them through the foam and it's a fairly simple job.
I plan to finish this today. My wrench was too short so a buddy lend me a longer one to get in that tight spot under the fender. Thanks for the tips guys...
I don't remember what I used (socket or flat wrench) but I didn't remove the rear wheel.
Here is a pic of the narrow bar installed. Looks better IMO.
