Out of options for popping Propipe
Just wanted to update on my situation with persistent popping from a V&H Propipe. I have had 3 Dyno runs from 3 different HD Dealers in the St Louis area and none have been able to help. The last one was from the Midwest's Guru of Dyno tuning and he wasn't able to help. My dilemma is, that most shifting from 1-2-3, or deceleration of throttle at around 2000-3500rpm's I get a loud bang, or Pop. Sometimes loud, sometimes not. I believe, and have been told by HD Tech's, it's the ejection of unburned fuel in the head pipes. This popping is especially present when the pipes are hot. Not that some decel popping is a bad thing but, this is more than the average bear. I've even had people i rode with say something about it. It sometimes sounds like a backfire. I have pretty much worn out my welcome with the dealer's as they tell me to live with it. I have talked to other Propipe owners and they tell me they don't have a problem at all...I guess I was thinking I could find what was causing it but, not so far. I spoke with a V&H Exhaust Tech and he thinks that my upgrades on this Glide "may" be too aggressive for the engine. I have a 2011 Streetglide with a 103, SE A/C, SEPST, and the Propipe. I thought these upgrades would be a benefit. Is this too much for a stock engine. Is a cam the next alternative. I will have torque cones installed Saturday to see if that makes any difference. Any ideas would be appreciated .
I had the same problem on my Street Glide but thanks to some of the good people on this forum, I was able to go into my Power Commander map and add some fuel to the zero throttle positions in the RPM ranges that I was having the popping at and all but eliminated the problem. Don't know if the SEPST allows you to do that but I would sure find out.
Would you post you Dyno runs please.
(hard to believe that the three HD dealers cant get a stage I tuned)
If you have your stock exhaust (yes I know it a PITA) try it and see if your still having the problem. (Its a cheaper deal than paying the Dealer to troubleshoot it, ie: could be plugs / gap or wires, air leak in the exhaust system, tune (AFR too rich), Throttle position sensor, OX sensor, etc.)
