Stupid oil change question
So I'm changing the oil myself for the first time. I've built a race car and have been serviceing all my cars for a hundred years, how hard can it fricken be to change the oil in a bike. Of course the oil filter wrench the dealer told me I needed to clear the Crank Position Sensor won't fit between the sensor and the filter. The sensor looks like it's about an 1/4 inch in front of the filter and sticks out past the outside diameter of the filter.
Will the filter actually unscrew past this sensor and how stupid and hazardous would it be to pull the crankshaft position sensor change the filter then reinstall the sensor?
Thanks
Thanks
I use a rubber strap wrench as well. I don't want to be banging around in that area with a metal wrench or metal strap. The K&N nut on the end has proven to be a great idea.
Sure, you can remove the sensor, it won't hurt anything, but you really don't have to do that. The filter will be off the treads in time for you to work it around the sensor.
You didn't mention the damn mess that the oil makes when you unscrew the filter. Well, there are many techniques to try to contain that oil so it won't drip all over your voltage regulator and all of the wiring and hoses and frame members underneath the filter. Some people don't care about it, but I have always hated that oil getting on all of that stuff.
Most of the harley techs just let it spill all over the damn place when they charge folks out the *** to change their oil for them. So do better than others.
I've tried several tricks, and there are actually some commercial gizmos that may work pretty well. But I've settled on using a freezer bag, working the bag up on the filter with the top of the bag pressed up against the filter bracket. It's not 100% effective, but about 98% effective in keeping the oil off the other stuff. The oil filter just falls down in the bag, oil and all, you zip it up and properly dispose of it. The bag works well to keep the mess contained. Again, there are lots of ways to do this, so maybe try a few to see what works best for you.
BTW...Hand snug the filter, then tighten 1/4 turn more. Done. Don't use a wrench to tighten the filter.
