S&S T111 in 98 Road Glide
It says right on S&S's web page that this engine will only fit 99-06 touring bikes:
http://www.sscycle.com/feature/featureview.php?s_id=27
To me that means it's for early Twin Cam frames. Your bike is an Evo.
Here's a similar engine designed for your bike:
http://www.sscycle.com/product/Evolu...ne-p21079.html
ocezam
First of all thanks for your Valued Advice! I assumed that since they make an adapter to put a HD Twin Cam Engine in an Evo Frame that a T111 would also fit. Maybe their configuration is different. The S&S T111 available to me is only $3000 and is still in Crate and comes Complete with Injection,Charging System,Regulator and Wiring Harness. Just assumed I could make the exchange happen. Guess I will put it up and wait till I find a 99-005 Bagger to slide it into!
Thanks Again
PackN
Thanks Again
PackN
Ba boom!! http://vulcanworks.net/SS-Twin-Cam-M...ate-p-189.html
Have the T111 in my ride(2004), like it alot. FYI, S&S had a bad batch of valve springs, one of mine broke 600 miles into break in. They covered it, but a pain in the *** still.
The date on my Certificate of Origin is 06/15/2011. When the engine died and I called Tech support all the guys I talked to had a good idea it was a valve spring, saying the had gotten a bad batch of beehives.
My advice would be to call S&S and give them the SN# and ask them about it, better to change now then when you're stuck out on the road.
Cheers
Cheers
