2007 Electra Glide Classic primary leak.
I had my inner primary bearing replaced at an indy, and now I have a primary leak that is coming from the back side. Is this something that commonly happens after an inner primary bearing change out?
When I showed the leak to the indy he stated that there's no way this should happen since he used all brand new seals everywhere.
He is tearing it apart again, but I feel that this was mistake on his part , but have never done a change on my own, so have no idea what could have gone wrong..
No, it shouldn't leak....... that being said.... it doesn't necessarily mean he did something wrong.... could have been a weak seal..they are MASS produced so sometimes a not so perfect one slips through .. I've replaced seals on things before and have them leak. Or yeah, he might have not had it lubed enough or not had it perfectly lined up and tore a small spot on the lip when he put it together or had it slightly cocked and wore it funny.
landslide03
11
06-07-2012 12:55 PM
