88" to 95"?
Old 07-26-2012, 05:42 PM
buford's Avatar
buford
buford is offline
Default 88" to 95"?
I know this probably belongs in the engine section, but wanted to ask the touring folks on upgrading an 88 to 95. (Jugs & Pistons) I have over 70k miles (motor still running good) and am thinking on going a little larger to get some pep back. Couple questions.
1. Is it worth the change in power or should I just hone and re-ring?
2. Is it reliable?
3. More shake in the motor? I drive primarily hwy miles
4. Larger jetting for the CV carburetor I'm assuming?
Thanks for your responses
Old 07-26-2012, 06:24 PM
05 Ultra's Avatar
05 Ultra
05 Ultra is offline
2 words
DO IT!
The best mod I ever had done.The motor is just as reliable. Get the gear drive done at the same time if you intend to keep your scooter for any length of time.
Old 07-26-2012, 06:27 PM
2002flstc's Avatar
2002flstc
2002flstc is offline
I'm not really the guy to answer your questions but I did my softail from 88 to 95 and I love it... done 40k since the 95 kit install and no regrets
That being said... I pull a trailer loaded with tools for work and loaded with camping gear when I go to Sturgis and she pulls the hills without breaking a sweat. I'm sure the andrews cams help with that though...
Old 07-26-2012, 06:34 PM
Challenger's Avatar
Challenger
Challenger is offline
I have the 95 kit. Love it, just wish I did the gear drive cams though
Old 07-26-2012, 07:18 PM
BeavisRules's Avatar
BeavisRules
BeavisRules is offline
I did the upgrade to my 06 Streetbob. 95 with gear driven cams.
Bike was an absolute BLAST to ride afterwards. More power than I ever needed. It would pull in sixth gear all the way to 120 and still want more.
I say DO IT.
Old 07-26-2012, 07:53 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,637 Likes on 4,630 Posts
2. Is it reliable?
1) yes!
2) yes!
3) no!
4)most likely (depends on how its jetted now)
Old 07-26-2012, 08:04 PM
Pumba11's Avatar
Pumba11
Pumba11 is offline
I have no idea of your financial situation. But I was so Pleased with the performance gain from my Andrews 21 cams that I put the 95 out of my mind. Spent the money on more riding adventures.
But if money isn't an issue go for it!
Old 07-26-2012, 08:12 PM
davessworks's Avatar
davessworks
davessworks is offline
Yes
now what's the question?
Old 07-26-2012, 08:21 PM
gambler's Avatar
gambler
gambler is offline
I would do cams as well. If you do the jugs on a stock motor, it will perform well, but you will really get the most out of the motor if you also do cams...especially at 70k. You should have your cam chain tensioners checked anyway. Many have failed well before 70k. When they go in to check the tensioners, they are halfway into the job anyway, so again, might as well do cams along with the jugs.
Old 07-26-2012, 11:30 PM
Bandit4142's Avatar
Bandit4142
Bandit4142 is offline
I just went from an 88" to an S&S 97" with 570 Gear Drive cams, and absolutely love it. Probably the single best thing I've ever done to any of my bikes.
Quick Reply: 88" to 95"?
