Just use plenty of lube on the cables... use a push/pull action and the cables will slide thu!
Took me 20 min to run the cable on my 07 SG..12" PYO bars.
They dont disappoint. I promise on that one. I almost went with evil apes but I love the lines of those gangsters too much. The internal wire install was alot easier than I expected. And for the price vs. yaffe... I'd do again.
And without tbw I could see that but you throw another set of wires in there and good luck...
I ran my 12" MBB's a few weeks ago, took about 30 minutes to run both the TBW with the connector and control wires through using the same technique. I taped the TBW connector along with the heated grip wire double with electrical tape, put grease on them and then ran the control wires through also with grease. Went through with very little struggle using a small push/pull motion with a few twists to work it through and took my time so I would not tear or cut any wire during the process. Completely do able but the connector on the other hand took me an hour and half to get all reconnected and ready to put back on the bike but I am color blind and had to triple check everything.
I'm not saying it can't be done I'm just saying that a lot of people minus a few have had difficulty running the wires as they are not the cleanest inside. Me personally, for that price they better be butter to go through. Those carlini's were super clean inside. Just saying. Plus everyone has monkey bars...
