Lots of noise when starting hot
Old 07-30-2012, 02:07 PM
c50plus's Avatar
c50plus
c50plus is offline
Default Lots of noise when starting hot
I had to change my starter when the bike was around 25K miles. Now at 52K miles I think
it might be time again. Maybe these things are only good for 25 K miles.
Anyways, here is my issue now. When the bike is hot and try to restart the starter grinds
and there is lots of nasty noises. It usually starts on the second try but on that first one it makes some nasty noises. But this does not happen whne bike is cold. I didnot have this problem before. Could this also be compensator related . This si an 08 Ultra.
Thanks
Old 07-30-2012, 02:42 PM
Gearhead3's Avatar
Gearhead3
Gearhead3 is offline
Usually a bad comp is accompanied by a loud 'banging' sound on startup. This is caused by the comp spring becoming weak and allowing the comp to bottom out when starting the bike. Does yours do this?
Old 07-30-2012, 02:58 PM
c50plus's Avatar
c50plus
c50plus is offline
No it does not do that, not loud mechanical BANG, just lots of grinding and
screaching sounds. Only when hot
Old 07-30-2012, 03:10 PM
screaminroadking's Avatar
screaminroadking
screaminroadking is offline
c50plus,
I feel your pain. 18.500 miles on my 08 CVO Roadking. Starter grinding so bad and frequent, it is being replaced (on my dime by the way) The bike has actually made a grinding sound at start up since it was almost new. Kept being told that was somewhat normal on the 110"s Hmmmm so I guess that replacing the starter at 18.500 miles is somewhat normal too. Whoda thunk?
Funny the dealership had none in stock. They had to locate it from another dealership, I guess there has been a demand for Touring starters, and the chrome ones are back ordered until who knows when.
Are these new starter's any better than the original one? Guess I will soon find out.
Old 07-30-2012, 08:16 PM
badger401's Avatar
badger401
badger401 is offline
My O8 Ultra does the same thing, been told it's "normal" but it sure don't sound normal. Scares the crap out of everyone around me when it does it.
Old 07-30-2012, 08:50 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
I just had a problem with what I thought was the starter on My 08 UC. Starter would make the same noises that You describe. Turned out to be a bad battery, believe it or not. It was the orginal battery with 46K on the bike. The starter was actually engaging and disengaging while trying to start the bike when hot. It made a hell of a noise. Had the battery load tested, and it was'nt putting out enough amps to keep the starter engaging properly. Bottom line, replaced battery a week ago and no more noise.
Old 07-30-2012, 09:16 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Now that's good to know!!
Old 07-30-2012, 09:45 PM
cmancini26's Avatar
cmancini26
cmancini26 is offline
I had (have) the same problem 07 fxd I asked a tech about it he said even if in neutral pull clutch in hadn't done it since
Old 07-30-2012, 09:51 PM
Jeff W's Avatar
Jeff W
Jeff W is offline
Just been experiencing this very same problem and was figuring battery. Gonna have to get one soon.
Old 07-30-2012, 10:58 PM
HTNHARD's Avatar
HTNHARD
HTNHARD is offline
SE Compensator solved all my starting issues. Kickback, whining, any noise is all gone. Bike starts like a dream everytime, all the time, with one quick push of the starter button. Easy job to do by yourself. Great writeup on this forum about it. You can try everything else but I would start there along with a new battery. Good luck.
Quick Reply: Lots of noise when starting hot
