Check Engine Light - DTC Help Please!
So on the way home from work today I tried to use my cruise control and it wouldn't work. Shortly after trying it the Check Engine Light came on. I had oil pressure, no pinging, and didn't smell anything burning so I finished up the ride home which was about 10 miles.
I hooked up my PowerVision when I got home and pulled the information below from the ECU. Does anyone have any ideas on WTF is going on? The obvious part to me is some ABS brake issue.
Beginning operation: ReadDTCs
PV Serial #: ANAJR000AA001229
Firmware Version: 1.0.7-971
Firmware Build Date: Oct 25 2011 23:09:48
Tune Database Version: 0.0.9.7
ECM: 1 trips since last DTC.
ECM:P0572 HIST
Brake Switch Low
ABS:C1094 HIST
Front brake switch always on
ABS:C1214 HIST
Rear brake switch always on
80:B2017 HIST
Tachometer:U1016 HIST
Loss of ICM/ECM Serial Data
Instruments
Tachometer:U1040 HIST
Loss of ABS Serial Data
80:B2021 HIST
End of operation.
ECM:P0572 HIST
Brake Switch Low
ABS:C1094 HIST
ABS:C1214 HIST
80:B2017 HIST
Instruments
80:B2021 HIST
End of operation.
I'm going to load it in my trailer Saturday and drop it off at the dealer.
Thank you for the reply!
Shout out to Frederick Harley-Davidson in Frederick, MD for fixing my bike in less than an hour.
I called at 9:30am and they said bring it in at 11am so I loaded it up in my trailer and dropped it off at 11am. I hung out in the showroom and 11:45am they called and said it was done.
The rear brake switch was the issue and it was fixed under the recal at no cost. Amazing that the rear brake switch fires all the DTC's I posted.
heavymetalthunder
07-21-2019 07:51 AM
